On both my factory rep. ride and with my RV10 checkout CFI I recall them emphasizing the ability to make rapid descents in the plane. I had come from a Cessna 172 and really stuck with 500fpm, but I recall 3000 fpm on both the above rides.
Due to wx changing a bit yesterday I cut short a flight. Clouds seemed to be 6000-9000, I was 9500. 20 miles from home there was an opening that I circled down in, but towards the end I was 2500fpm to make sure I was clear of clouds, saw my CHTs get lower than expected. So I have been going down the shock cooling rabbit hole online.
If I were to take what I am learning and critique myself it would be that I likely enriched my mixture too much too early and should have done so incrementally as I descended.
The critiques of others online have me trying to learn and understand things better.
How often do you descend more rapidly than 1000 fpm?
How much do you pull the power back and push in the mixture?
