I'm looking at section 36, 56, and 58 to do the servo bracket installs while I have the tailcone free before the big join. When I rivet the yaw servo mount (F-14189A/B) to each other and F-01407-L/R, will I be able to remove the bellcrank plate (F-14139)? I'm wondering if others can let me know if that's true, because I'd like to just do the servo bracket installs, but not all the hardware and the actual bellcrank at this point. From what I can tell with the nut plates, F-14139 is removable otherwise. It looks like the F-14139 could slide forward from under F-1489A and come out to work on later, but I don't want to get myself into a bind and not be able to do that.
If anyone has done this, or has removed the bellcrank mount at a later point, or has any suggestions, please let me know.
