I did a few on tanks that i fixed (leak repair). I just used a couple earls an fittings and ordered a 3’ section of aeroquip hose. Cut to match your existing hose and then assemble. I do all my lines this way. It is not that difficult on e you get the hang of it. If this is a new build, aren’t the lengths listed in the plans? I am a 6 builder, so not sure how much details is in the modern plans. Back then we got more drawings than instructions.Hi all, can anyone tell me the physical length of the inverted fuel pick up fuel line? Have the hardware, just need to source a fuel line the correct length because they are unavailable through Vans atm. Thanks.
Most all flop tubes are made from Aeroquip 701/Stratoflex 156 hose. "Rubber' liner. Spruce has them, in different lengths with the counterweights. But, if you like, get a 2 foot piece of -6, remove yours, cut to fit, cut off the crimp collars, then reclamp the counter weight.The -7 I purchased came with the flop tube installed. A guy asked me if my engine had an inverted oil system? No? Why have an inverted fuel system without an inverted oil system?
They also pointed out the flop tank has about 2 gallons unusable.
I already reassembled and resealed the tank. I still don’t have inverted oil….Most all flop tubes are made from Aeroquip 701/Stratoflex 156 hose. "Rubber' liner. Spruce has them, in different lengths with the counterweights. But, if you like, get a 2 foot piece of -6, remove yours, cut to fit, cut off the crimp collars, then reclamp the counter weight.
Did anyone actually answer your question???? I'm guessing you were looking for something along the lines of 16" B-nut to end of weight??? Sorry I cant help either, mine is installed and the tank sealed up. You are super polite! I am with Rockyfatcat though and "future proofed" my airplane.......Thanks everyone!
Its all good thanks mate. Unfortunately the old hose was disposed of before we had a chance to take measurement. I have all the fittings and counterweight but probably safest bet is wait until they’re back in stick at Vans and order a new one. Cheers.Did anyone actually answer your question???? I'm guessing you were looking for something along the lines of 16" B-nut to end of weight??? Sorry I cant help either, mine is installed and the tank sealed up. You are super polite! I am with Rockyfatcat though and "future proofed" my airplane.......
I removed my flop tube last year, as it was due for replacement, but decided to go to a normal fuel pickup. The consensus is that it is not necessary for most aerobatics. Anyway, it is still on the workbench. Measured the hose this morning. From the tick mark on one ferule to the tick mark on the other ferule, measured 8 7/8".Its all good thanks mate. Unfortunately the old hose was disposed of before we had a chance to take measurement. I have all the fittings and counterweight but probably safest bet is wait until they’re back in stick at Vans and order a new one. Cheers.
Best regards, Merrill
I have thought of doing that as well. Some have said it isn't possible.....I removed my flop tube last year, as it was due for replacement, but decided to go to a normal fuel pickup. The consensus is that it is not necessary for most aerobatics. Anyway, it is still on the workbench. Measured the hose this morning. From the tick mark on one ferule to the tick mark on the other ferule, measured 8 7/8".
To clarify, I removed the flop-tube and capped the inverted fuel exit at the front of the tank. Then installed Van's standard fuel pickup that exits from the stock inspection panel. So now, the fuel supply lines from both tanks are the same and stock non-inverted configuration. Sorry for any confusion.I have thought of doing that as well. Some have said it isn't possible..........but if a flexible tube goes to the aft section of the tank, even though it's from a different exit fitting location, a stiff one should go there as well. It just needs to sit where the original plans have it sitting from the mid-tank fitting. Do you have pictures of yours?
Yes - rubber tubes have a ten year life if I recall correctly. I just changed out the new, never-seen-fuel 20+ year old flop tube on my F1 project, and probably should have just installed a standard pick-up - while I do a fair amount of aero, it is all gentleman’s stuff at this point in my life, and inverted fuel isn’t necessary (as stated above). I figure that 10 years in the Rocket could well be as long as I fly it - who knows?This has turned into an interesting discussion about removing this flop tube completely. Why are you all doing this? Does the tube need replacing periodically?
Unless you have inverted oil, (and fuel injected)why would you want inverted fuel? A sustained negative G flight, do you really want the engine making power while the oil pressure goes to zero? I like that my engine will lose power if the oil pressure goes to zero. I also like the ability to use all of my fuel.. I have almost no unusable fuel with my standard pickups.This has turned into an interesting discussion about removing this flop tube completely. Why are you all doing this? Does the tube need replacing periodically?
AN cap. You can buy from Spruce. It makes a good purge fitting should you need it someday.So how are you guys sealing off the fuel pick up hole in the tank where the flop tube connects?
Having just done it not eh wing rack, I’d say that you’d need rubber arms with no bones to do that….but I haven’t tried, so can’t; say for sure!Is it possible to replace the flop tubes and/or change to a standard pickup without removing the tanks from the aircraft?
Asking for a friend![]()
Yes, I did it. It is a stretch to do it and you need much patience and a sense of position when using a wrench, by feel, etc. Also, mirrors and very good lighting in the tank. After removing the flop-tube, the difficulty of doing that (along with the consensus in many threads here, that the flop-tube was not necessary) lead me to not replace it, but change to a standard pickup.Is it possible to replace the flop tubes and/or change to a standard pickup without removing the tanks from the aircraft?
Keep us up-to-date on your method of your conversion. Leaving the tank on? Curious minds want to know...........!After much deliberation, I’ve decided to revert to a standard fuel pickup and ditch the floppy tube. My aeros will be of the gentle positive g type. This will save maintenance down the track also. Thanks everyone for the ideas and perspective. Cheers
Yep---eat lunch first----NOT alot of room in the wing root to be working on that.Is it possible to replace the flop tubes and/or change to a standard pickup without removing the tanks from the aircraft?
FWIW, on my right tank with the standard fuel pickup, unusable fuel is 4 ounces. On the left take with the inverted pick up, unusable fuel is 13 ounces.The -7 I purchased came with the flop tube installed. A guy asked me if my engine had an inverted oil system? No? Why have an inverted fuel system without an inverted oil system?
Probably the issue is that the 90* fitting is pointing too high. Ther is not a lot of flex in those lines and must get it centered if you want it to make it all the way to top and bottom. Putting the fitting too far aft also shortened the length, reducing the flex.Quick note...
I was recently asked about wildly excessive unusable fuel, after the installation of a flop tube by a popular shop. I wouldn't have believed it if I hadn't seen it, but it turned out the tube was installed in the wrong place, thus the clunk weight couldn't reach the bottom of the tank.
Correct:
As installed, aft of the tank support angle:
Tube too short, incomplete trap door, open lightening hole in rib, and no anti-hangup protection. Trust but verify.
I'm not sure a rub rail as you show was in the info packet.
After procrastinating for too long I decided to dive in and replace the flop tube in the right fuel tank. Figured I would try to do it with the tank in place on the aircraft and the back up plan was to remove the tank. Happy to report that it is indeed possible to replace the flop tube on an RV-8 with the tank in place.es, I did it. It is a stretch to do it and you need much patience and a sense of position when using a wrench, by feel, etc. Also, mirrors and very good lighting in the tank. After removing the flop-tube, the difficulty of doing that (along with the consensus in many threads here, that the flop-tube was not necessary) lead me to not replace it, but change to a standard pickup.
Merrill
