csmith3603
My problem is when I turn on the Avionics switch the Radio (GTR200B) comes ON and Squeals thru the headphones!
So,,, the circuit with the squealing's is coming from the Avionics switch wiring! The Radio (GTR200R) was bench tested
for 120.00 and was Ok.
The NavCom breaker fuse did blow and was replaced.
I was told by support to test very fuse except Com Fuse to see if the sequel goes away.
The only thing not checked yet is every fuse in the Rotax 912iS Fuse Box! There is NO documentation for this Rotax 912iS fuse box!
Could it be A AV-60000 issue?
