I installed a Surefly Sim4 in place of a slick impulse mag on the left side of an (I)O-360 and I'm having an issue with mag checks. When going back from Right to Left on the way to both I get a engine miss because there is no overlap and both are grounded for a split second. At idle it is no big deal, but at runup power it feels abusive to the exhaust system. I want to ditch the key switch and install separate rocker switches for each mag and a momentary for the starter. Requesting suggestions for switch part numbers that are appropriate and durable. Thanks!
