The only rivets the RV-8 instructions say to do before setting most skin rivets are the two rivets on the mid side skins that are in front of the lower spar bar. The RV-7 instructions make more sense here I think.Dunno about the -8, but on the -7 the instructions call out setting those rivets before the side skin is clecoed to the fuselage assembly.
They actually were pretty easy to do. I do need a helper for some of the rivets on the bottom of the plane. My wife said she’d help but when she helped with the wings she started complaining after about 5 minutes of having to hold the back riveting bar. Said it was too heavy. So I think I’m going to have to call outside help.I bet you wished you had a helper on those....
