outnumbered
Trying to decide between these two options for transponder antenna placement. Any thoughts/feedback?
In tunnel right behind firewall
Pro's - Short coax length to GTX-45R (which is behind the panel)
- center of fuselage
Con's - Close to exhaust (not sure of this really would be an issue)
- any issue being right up against the firewall (i.e. wouldn't be able to support fuselage from below in that area if needed for maintenance)
In rear next to battery tray
Pro's - open area and easy install
Con's - longer coax run
- not centered with fuselage
