Installing this optional kit I found they only use 3 nutplate/bolts to attach to firewall, yet the angles are drilled (for bolt and nut plate for 6).
Have it drilled up for three, but I think I will go a head and drill the other 3 for total of 6. I see no downside except weight and expense.
Suppose I could "blank" those nut plate and bolt holes in the angle with rivets.
Comments, suggestions?
Rubbing, Fretting, battery box to firewall and box to battery. I am thinking some teflon tape to keep two metal parts not attached from buzzing and vibrating? Heat is an issue.
