The Field Wire from the generator receives it's electrical power from which source - does the 'airframe end' of the Field Wire connect somewhere on the Vertical Power Unit? We have scoured the schematics and can't find an answer to this. We can't make a first flight until this problem is solved. RV-12 number 120188. ULS engine. Thank you all for being here - I appreciate.
