Opinions please: This is a new one for me. Installing a forward sump IO-360 on an 7 after a fresh Overhaul. Took a couple of intake pipes off to facilitate installing other things. When reinstalling these intake pipes the big red O ring ends up very deep inside the sump bore. The #2 intake pipe is almost impossible to install without the O ring going into the sump. It’s like the pipes are at least 1/4” too long or the O ring carrier/holder part is in the wrong spot. The machined bore in the sump where the O ring lives is a bit over 1” long. One would think this is to accommodate intake pipes of slightly different lengths and the O ring would live near the middle of this bore, but in this case it’s right on the inside edge. I sent this engine in and assume I got the same pipes back. Have calls into the shop and have not heard back yet.
Don Broussard
RV9 Rebuild in Progress (Painting now)
57 Pacer
Don Broussard
57 Pacer
