Believe it or not, the 13th was my 5 year anniversary of being hired part time at CAE for simulator seat support in the Phenom 300. With 530+ sessions and five years under my belt now, I’ve been assigned the nickname ‘The Seatfather’.
1000+ hours on motion as a crew have *REALLY* altered my approach to flying safety and how my brain works in the air. I wish I could have transferred this current mindset into my knucklehead brain of two decades back. I remember thinking I knew a lot about flying (didn’t). Still learning - hope to never stop.
Wishing you a happy, safe and RV-filled weekend. Plans for a short hop in the RV-6 this weekend maybe in the works. Smiley face for sure.
v/r,dr
Build Update …KazooRV-9A
Getting closer to putting the RV-9A up on the main gear. Am looking forward to that visual progress! All FF wiring is complete, and have been testing the EIS/EFIS inputs before riveting the top front skin in place. Wiring and panel installation has been a long process.
RE Fuel Flow …bwagner PIREP
RV-14A, Thunderbolt YIO-390-EXP340 installation. Firesleeve encasing the red cube and all of the lines in/out. An exhaust shield on that nearby pipe.
FF readings have been rock steady for the 80hrs in service thus far.
RE Tail Wheel assembly, torque tube vs chains, tire recommendations RV 4
…Pete O Static PIREP
I honestly can’t remember the cost but it wasn’t crazy or anything. The Ti spring is obviously quite a bit lighter than the steel but also a lot springier. I now have a nice suspension on the tail but with that, one needs to be aware of clearance between the tailwheel nut and lower rudder fairing. I have never had an issue but another reason why I ordered the Aero Garage fork is because that nut is eliminated. A friend of mine who is a mechanical engineer advised me that titanium is prone to cracking if it gets chipped, say from a stone chip. My spring is wrapped in hockey tape to protect it and I unwrap the tape and inspect the spring at each condition inspection.
Here is a pic of the lite links currently installed. Just awaiting the new fork and axle. Amazing how much weight can be reduced from the tail and at such a long moment, it makes a marked difference on the C of G location.
bbaggerman
…eScooter PIREP
Daddyman58
OFF TOPIC:
v/r,dr
RV-9A Andy C. Kalamazoo, Mi
I think that's great advice. I've been thinking that putting some fuel in the tank for testing should be a plan. I intend to paint the wings before final installation, and I could imagine that even primer/paint could initially seal what might later become a leak. And what a pain it would be to...
vansairforce.net
Fuel flow
Recently my fuel flow readings went from about 9 gals per hr. To around 16 gallons per hour,would these be a bad fuel flow transducer?. I have the lycoming io-390 thunderbolt with ft-60 fuel flow transducer.it’s mounted per plans for the van’s manual.
vansairforce.net
Tail Wheel assembly, torque tube vs chains, tire recommendations RV 4????
Gonna change to double fork tail wheel assembly from single fork. Please share advice, thoughts and recommendations.
vansairforce.net
bbaggerman
…eScooter PIREP
E-scooter
what scooters have some of you purchased to haul (RV-7A) mainly looking for decent speed price and distance. also something that can work as a regular scooter incase the batteries die. want to use in the event of no crew car availability.
vansairforce.net
Daddyman58
Brake groan update
I have experienced an annoying loud groaning when I applied my left brake. The brake functions normally, and stops straight. But the noise was bothering me (and perhaps others). I examined it closely, and could not see anything that would cause the mystery noise. Yesterday, I couldn't stand it...
www.vansairforce.net
OFF TOPIC:
vansairforce.net
vansairforce.net
