I am trying to run my O-320 LOP at approx 65% power and the Cylinder #3 is causing a little bit of a trouble. It peaks much earlier than the other three cylinders and I have to stop leaning after about 1.5gph "gami spread" due to engine roughness. With that mixture EGT3 and EGT4 are running LOP but EGT1 and EGT2 are still at the peak. The #3 is running is very lean and its CHT is dropping below 300F range, while the other 3 CHTs are staying in the normal mid 300s.
Here is what the chart looks like
Do you think I may have an induction leak on #3? I have tried the "savvy aviation" induction leak test (also seen on the chart) but not sure if tells anything.
