I've been going round and round on trying to get this one solved with no luck.
I'm running the G3X/GEA system on my 7A. The oil temperate probe (2 wire UMA1B3A-2.5R with about 3' of 22 g shielded pair wire and UMA probe in GEA selected) has been reading low. The higher the temperature, the worse the variance. Testing with known temperature heated oil (and verified with 3 thermometers), it's 35 degrees too low when at 290 F and slowly gets better as the oil cools. So at 220 F it reads 207 F, at 200 F its 188 F and at 180 F it reads 169. Finally around 100 F it's nearly spot on. Garmin replaced the probe and I have the same results.
I've tested the wiring, connectors, just the probe, grounded and ungrounded the probe and can continually replicate the inaccuracy. I've tested the probe both at the leads and back at the dsub pins just to verify the wire run isn't a problem either and then ran a new run of wiring to the GEA just to take that issue out of the equation.
Garmin said to try adding an inline resistor. Which I will do just to keep the support moving forward, but I've not come across anyone who says this is a solution. I assume this will skew the entire range and while it may fix one side, the other side of the temperatures will be off. But I'm pretty remedial when it comes to electrical theory.
I've also tried all the different probe settings in the GEA and that doesn't do anything. The probe resistance tests pretty close to what it should be at various temperatures.
Has anyone come across this or have any thoughts on solutions or things to try?
Edit; Moved to engine monitor
