Currently working on mounting the firewall to the fuselage on a 7A. I spent hours yesterday meticulously mocking it up, measuring and measuring…and measuring the 5/8 setback. I finally drilled the flanges to the side skin. All turned out well except for the one top hole (or bottom as it’s upside down of course). I tried everything, including hitting it with a hammer from behind to move it forward. No luck. The end result is the setback on that one hole on each side is about 11/16 and the hole violates the edge distance. Anyone else have similar result here? Wondering if I should add an extra hole/rivet or make a backer plate for those holes/rivets. Very frustrating.
