Countersink in fiberglass wing tip for a dimpled skin.
WayneJ
Ambassador
On page 24-03 step 10 we I are to c’sink the #27 holes to fit the dimples in the skin. So it is a dimpled aluminum skin fit into a fiberglass c’sink. If these were two aluminum parts nesting and riveted I would c’sink .007” deeper than flush per Section 5. But this is different than a riveted joint. How should this countersink in the wing tip be sized?
You can also consider taking the roughly 1” edge that you cut off the inside of the wingtip and rebond it back on the inside
of the new edge. Scuff up both mating surfaces, a little resin w/flox. This adds some ridgidity and volume for when you ultimately C/S for the dimples described above. I did this, and am happy with the result. YMMV.
On my old -7 build, I epoxy glued aluminum strips inside along edge of the fiberglass. Purpose was to reinforce the nutplates in the glass. Like BAR's idea. Just wondering if anyone does the aluminum strips anymore?
I debated on doing an aluminum backing strip and the feedback I got was that it wasn't really necessary so I skipped it. There's enough surface area on the nut plates that I think it's okay without.
I did it and I'd do it again:
I did on the horizontal and vertical tips, with only pull rivets holding the back in those situations.
Hey Matt, How did you make the large countersinks? What kind of tool did you use? I've tried a regular 3 flute piloted cutter but it will likely be too dull to finish the job. Some builders are using a piloted Perma-Grit tool. That would be done without a microstop cage tho. So gaging the depth by eyeballing it?
And more to the point of my original post. How deep to make the countersink. Is it there to clear the dimple so the skin sits flat to the flange? Or is it meant to locate the dimple and lock the assembly as it would in a metal to metal assembly?
I like the idea of using aluminum strips here. Wondering about something else in your pictures. What kind of nut plates are those. They look like maybe the floating type.
Yup, exactly, I used the Perma-Grit piloted countersink tool and just went slow. The aluminum strips work great here for keeping the pilot centered. I dimpled a piece of scrap and used it as a gauge to check my countersink depth; it doesn't have to be tremendously precise, I just went for a good fit. And yes, I used floating nutplates so everything would line up.
My full wingtip build sequence is here: https://www.rv7blog.com/category/wings/wingtips/ (newest post will display first)
Not a 14, but I had to countersink fiberglass quite often for screws, rivets, dimples, etc.
I bought a Dremel stone and ground the business end to the correct angle by gently running it on a grinder wheel.
It's been used for the entire build. I don't fo full depth. I get close and finish with a few turns of the countersink tool. No dull bits and the stone was cheap.
