Note: .STL file at bottom if you want to print it, but you can design your own just how you want it in like ten minutes. It's pretty easy to learn and do. You should!
More fun playing with 3D design and printing - this time a fuel cap opener (which may break in half the first time used (<grin>).
Constraints:
Shapr3D (https://www.shapr3d.com/) allows free use for hobbyists. It does however restrict the free use to low res export. Curves don’t necessarily look like curves. I’ve found that rounding off the corners of various edges gets you pretty close to where you want to be, even with the free version.
Also, the free version only allows you to keep two projects at a time in the software. No big deal if you store your other ones in the cloud somewhere and drag them into the software when you want to work on them.
So, back to the fuel cap…
Data:
The first print (.25” thick) next to the second print.
The modified Shapr3D file with rounded edges:
Of course all this is going to change many more times. I haven’t tried it on the RV yet. Just having fun while Law and Order is on and I’m winding down.
Printed w/PLA on a BambuP1S. Print time under 6 minutes. 2.21g of filament.
Fun to play with.
v/r,dr
PS: As I get a fuel cap opener I’m happy with, I’ll update the thread (and attachment) here.
Download .STL file:
drive.google.com
Constraints:
Data:
Fun to play with.
v/r,dr
Download .STL file:
VAF_Fuel_Cap_Opener.stl
drive.google.com
