Started Stabilator Fairings and got a question above the recessed area. As shown in the plans they want a sharp inside corner so the the skin is somewhat flush with the fairing. See pic
I have a hard time getting that done. Tried using a file with edge teeth but not happy with results. Has anyone used a razor blade or heated the fairing to get rid of the inside radius. What did you do? The plans also give you a dimension of 040" from top of fairing to flange.
I made a boo-boo and cut away to much clearance for the rib bracket. Should I order another fairing or is there a fix.
