I recently noticed what I will call a knocking sound from the engine and can't seem to identify what's going on. I thought perhaps the collective knowledgebase here might be able to help.
Here's a link to a sound file which I recorded with my phone. (Apologies for the fact that you can hear me breath at certain points -- I wanted to keep the iPhone near my head so the microphone would pick up what my ears did.):
The recording starts at cruise speed and power setting, and I slowly pull the throttle out. At about 0:50, RPM is down to about 1800 and the knocking sound begins. The knocking start to abate around 1300 RPM. The sound is repeatable and does not seem to change with airspeed, attitude, or altitude.
De-cowled the aircraft and everything looks normal. My mechanic looked through it as well and couldn't see anything abnormal. I submitted G3X logs for analysis to Savvy and they compared it with other flights over the past year and do not see anything out of the ordinary. The knocking sound is not accompanied by any roughness or vibration, no power loss or surging, no unusual indications or anything else. Pressures, temperatures, etc all completely normal.
A little bit about the plane: IO-360-C1A powered RV-6 with a fixed pitch Sensenich GA composite prop. 9.5:1 compression. Dual electronic ignition: a Lightspeed Plasma III and a P-Mag.
Thanks for any help you can provide. This one has a bunch of people stumped.
--Ron
--Ron
