Paul you there?
Ok so after I (electrically challenged) completely wiring my G3X system and other items with no issues, the time came to power everything and test. All is well, but one issue I have is with my FLYLEDS standalone taillight. I have a 2 conductor shielded going to the tail. White wire going to position and the whit/blue to the strobe, then I followed standard shield drain termination installation procedures at the taillight plug. Both position and Strobe wires go back to panel to separate single on/off switches.
When i flip either switch, I get both position and strobe functioning which is not what should be happening. So then I started trouble shooting and ended up disconnecting the white/blue strobe wire at the tail end, then flipped on that same strobe switch at the panel and it is still operating the light. ?? So I'm assuming somehow in my cutting of the wires to install the ground shield drain I must have nicked the wires to where both wires are no longer isolated?
So then I left the shielded position wire connected and disconnected the shielded strobe from the tailight , then ran a separate individual wire from the strobe switch to the strobe and everything is working fine.....position flipped on only, good......then strobe on and it flashes. Separate functions.
So I'm not really wanting to run a separate wire to the tailcone again but would prefer to use the two wires already there of the two conductor shielded. I'm thinking I did something wrong from the disconnection points at the tailight by running shield terminations when i didn't need to except for at the very end at the tailight connection on the negative that goes to ground at the tailight. I've also disconnected that shield termination ground at the tailight and grounded locally at the tail instead and it doesn't change anything as far as the original problem.
The instructions say to run separate wires to the individual switches but I though I was being clever by running shielded wire for EMF noise.
Any ideas? Thx
Any ideas? Thx
