Inflight Pics/Vids
…CessnaTPA submits his
dr
JDA_BTR
rick57
Skykingbob PIREP on COMM Antennae Choices
jask
Spotlighted Classified
OFF TOPIC:
RV-12 Inflight Photos
Spring 2024: people all over the world come to Holland to see the famous Tulips. The Van's Forum has one advantage: the airplane I fly from is in the middle of it (and, to be honest, there is a photo-competition on flower-bulbs). I tried to make the link between the straight lines of flowers and...
vansairforce.net
dr
WDYDWYRTW? 1 / 18-19 / 2025
…getting this weekend’s thread started. Hoping you’re having a great weekend. V/r,dr
vansairforce.net
JDA_BTR
Hone rudder pedal tubes
I’m putting the WD-804-L/R rudder pedals on the outboard ends of the WD-816 rudder slide. There is too much friction. I’m to hone the rudder pedals. What is an efficient way to do that? I’m thinking a few hours with a red pad will be no fun.
vansairforce.net
rick57
Your advice, please, soon to take delivery of an RV 4.
I will soon take delivery of an RV4 in good shape. Pre-Buy mechanic and former four-owner suggested a tail beacon x and maybe an autopilot for long cross-country flights. I would appreciate your thoughts on whether to consider an AV 20 or 30 to go with the tail beacon X (no transponder now) or...
vansairforce.net
RV8 Comm Antenna Locations
Now that Google searches no longer return VAF search results I'm having a hard time finding what I'm looking for. I'm sure this has been discussed, but I am trying to find the best location for dual comm antennas on the -8. Both will be Garmin comms with CI-122 antennas. All I see in the G3X and...
vansairforce.net
jask
RV200 spinner back plate broke
The spinner back plate is two piece made of stainless. One piece is cracked in multiple spots and the other piece is also cracked. The pieces fit under the propeller nuts that hold the prop on. Each piece has a semi circle of holes that fasten the formed fiberglass adapters that also fasten to...
vansairforce.net
RV-10 Empennage/Tail kit for sale
For sale is one RV-10 Empennage/Tail kit with about 30 hours of work on it. Vertical stabilizer, rudder, and horizontal stabilizer parts are prepped to the point of priming, but have not been primed, so the priming choice is yours. If you decide not to, the next step is to set the first rivets...
vansairforce.net
OFF TOPIC:
vansairforce.net
www.vansairforce.net
vansairforce.net
