The spinner back plate is two piece made of stainless. One piece is cracked in multiple spots and the other piece is also cracked. The pieces fit under the propeller nuts that hold the prop on. Each piece has a semi circle of holes that fasten the formed fiberglass adapters that also fasten to the spinner. Both stainless pieces are broken in half. One is still fastened tight with the propeller bolts. The other piece also cracked at the two remaining propeller mounting holes. That fragment of the second back plate was then only fastened by the bolts to the fiberglass adapter plate.
The propeller has been discontinued and I will probably not be able to buy the pieces. I will call them tomorrow and also the former owner in El Cajon. I have several questions. I have owned the aircraft for three years and did a prop balance when I first got it. I used two weights of about 18 grams each on the Lycoming flywheel at 30 deg spacing. Why did they crack? The pieces have rounded corners but all edges are sharp. It is like these pieces were punched from a stainless sheet. One A&P has suggested that I will probably have to get the pieces fabricated. What grade stainless should I use? They need to be able to withstand the vibrations of the prop and yet not crack. The aircraft has less that 300 hours. Both pieces are cracked which means all of these props have problems.
