My RV7 is in the tie-downs at KSNA in Southern California. After last week's crazy winds, I'm missing the hangar space I lost over the summer due to construction and insane demand.
The aircraft was definitely bouncing around a bit in the wind. There was a clear bend to one of the tie-down "eye" rings (since replaced), and a friendly neighbor added an extra ratchet strap to the tailwheel. There was no visible damage or scuffs. After pulling an inspection panel and verifying no damage to the wing spar near the bent "eye" ring, and also ensuring no new play with the installed eye rings, I did a short flight.
During the flight, the right rudder pressure necessary to maintain coordinated flight nearly doubled. Rudder trim consists of a thin triangle of material bonded to the trailing edge of the rudder. The amount of right rudder pressure (as usual) varies approximately linearly with airspeed (more pressure is required at higher speeds).
Are there any thoughts on:
- Any concerns with safety? I flew my fair share of "bent" jets in the Air Force, so it seems this does not need to be automatically grounding.
- Any thoughts on the cause?
- Any thoughts on remedy?
