Dr.Looping
Dear Gentlemen,
I am new here and need your opinion to find the right way to optimise the cooling on an RV-4.
Facts:
I've been flying a friend's RV-4 this year. The plane is equipped with an O-320 (150hp) and a Catto 2-blade fixed pitch propeller. It is well built, with the emphasis on light weight and high speed.
In the quest for more speed/less drag, the cooling air intakes were reduced and a plenum was made. The plenum and baffles are really well sealed.
Since then the fast lady has very high CHTs in summer. In winter the temperatures are ok.
Opening the oil cooler has no significant effect on the CHTs and oil temperature.
I have also noticed that even with the cabin heater closed, warm air is still being forced into the cockpit from the front.
The owner now wants to start lowering the temperatures again. There are several ideas and we have done a lot of calculations. The question is which steps to take first.
Options:
Facts:
Options:
- Increase the size of the cooling air intakes: Currently the inlets are about twice 65cm²/10.075inches². According to an article by Dave Anders, I have calculated a minimum size of at least twice 75cm²/11.625inches². However, enlarging the inlets is very time consuming, creates more drag and changes the current beautiful appearance of the aircraft. If it can be avoided, it would not be the first choice.
- Augmented exhaust cooling: The owner's idea was to tackle this project first. However, this would require extensive modifications to the cowling and exhaust system. The question is whether this will have the desired effect if the air intakes are actually too small.
- Cowl flaps: As an alternative or in addition to increased exhaust cooling, cowl flaps could be fitted. The modification is not quite as complex. However, the same question arises as to whether this is of any use if the airflow from the intakes is too low.
- Optimise the oil cooler: The oil cooler certainly needs to be optimised. The question is whether this will be enough to bring the temperatures back into the green. Probably not, but it would be the easiest modification.
