rpigeek
We’ve been trying to diagnose and fix a low fuel pressure that we see as the fuel tank gets low (i.e 5-6 gallons). As we get that low if we are operating at 5,500 RPMs we’ll drops in the fuel pressure every couple minutes to less than 2PSI and sometimes even 0.9 PSI range. If we throttle back (i.e. 5000 RPM) the fuel pressure will increase to 2-3 PSI. When we add more fuel to the tank it we don’t have the problem except on steep climbs. I’ve replaced the fuel pressure sensor (just in case) and also replaced to the latest mechanical fuel pump. This is an older RV12 with a 912 ULS. Turning on the electric fuel pump helps, but doesn’t remove the drop we’re seeing.
Any recommendations where to look next? I was going to start to go through the fuel system to look for blockages.
