Long, long ago when I put together the center section bulkhead, I ground down the side of a plastic snap bushing so it would fit in the wiring hole that is on the outside portion of the bulkhead (ground down because part of the hole gets encroached on by the vertical 904D piece). Fast forward to today as I'm finishing up my wiring runs. Now with the landing gear in place (9A), a snap bushing won't fit in the hole because of the combined thickness of all the parts. Do I just need to look for snap bushings that can accommodate deeper material, or are there other options for a hole like this?
