dr
WDYDWYRTW? (12 / 21-22 / 2024)
...getting this weekend's thread started. No RV for me this weekend, as I'm working extra paper routes while people will use me during the Christmas season travel rush. We shared the ramp for a bit with a beautiful RV-7A in south Texas... ...and yesterday got the once every few months view...
vansairforce.net
RE: ShawnR’s RV-4 Build
An issue came up that I have not seen a lot posted about. It is mentioned at the end of this thread in post #11 but not resolved. I am having the same issue. Any else have to deal with this? I feel like the tube is too close to the mount, and engine vibrations could cause issues. The tube is all plastic.
Shawn's -4 re-build
An issue came up that I have not seen a lot posted about. It is mentioned at the end of this thread in post #11 but not resolved. I am having the same issue. Any else have to deal with this? I feel like the tube is too close to the mount, and engine vibrations could cause issues. The tube is all...
vansairforce.net
RE: 9A Cabin Heat
…rockwoodrv9 PIREP
I have an exhaust that may be different than many on an 0-320. It produces almost no heat - even for the carb heat. I have not found a way to get more heat. I have sealed every place I can find - put the aileron boots on and weather stripped the rail and canopy. There is still leakage around the instrument panel that I think comes from the tip up canopy seal along the foreskin. I tape over the exterior of the vents so no air can come through.
Here is a picture of my exhaust system. If anyone has an idea on how to increase the heat, please let me know. I was going to fly yesterday but it was in single numbers and that is too cold even with heated vest and heated seats. I talked to Clint last year about building a new system and that may be the best answer.
RV-9 Cabin Heat, but not so much
My RV-9A has a cabin heat issue, that is, very little of it. I have taken apart the heat muff on the Vetterman Exhaust and examined it. Nothing wrong there, the pipes fit tight with virtually no air gap. No gaps where the two halves fit together, no holes in the scat tubes in or out. The...
vansairforce.net
3D Printed Phone Cradle/Kneeboard Idea (dr)
….update
Designing a 3D Phone Cradle to Use Instead of Kneeboard
For the last few months I've been using only my iPhone in the cockpit, leaving the iPad home. Less stuff to keep track of on contract gigs and in the sim. Also, the phone is always with me and can talk to the Internet without tethering (my iPad is Wi-Fi only). Faster to file and amend flight...
vansairforce.net
Aircraft Extras, Inc. RV NEWS
Take a look at our “E-Z Out” Center Console for the RV-6, 7, 9, and 14. The center console not only adds more storage space, but you also may use it for leverage to get in and out of the aircraft. They are solidly constructed so that you can put your full weight on it as long as you secure it properly upon installation. We presently have stock on all consoles.
We also make other interior pieces such as seats and side panel armrests. Don't forget to check out our NEW "Oil Quantity Sensor" and some of our standard products; No Weld Handles, Relay Boards, Flap Positioners, Low Fuel Warning, Smallest Annunciator and our Tire Valve Extensions. Also check out these items below for some stocking stuffing More details at www.aircraftextras.com.
OFF TOPIC:
vansairforce.net
www.vansairforce.net
vansairforce.net
