This doesn't look like it's going to be a ton of fun.
According to Rotax-Owner.com:I believe it only applies to certified engines.
I'm not sure. The s/n is 7702217-100089222 and mine is 7705061. I need to find out what in the SB Rotax-Owner.com is seeing to add "and non certified"Just looking at the engine serial numbers, which are all certified. So…?
I didn't catch that on first skim/read. Glad to hear!And there’s a 200-hr minimum time exception, so if you’ve got that much time on the engine I guess they’re assuming it’s ok.
There is a separate SB document that covers non-certified.
Aside from the SB itself, this serves as a reminder that when reviewing technical info on your Rotax engine the best practice will always be to go directly to the source and look for your specific engine model. Even with the best intentions, third parties can filter out info or lead to confusion.
Technical Documentation | Manuals
Knowledge is safety: In our library, we provide technical documents, from manuals to warranty conditions to service letters for your Rotax aircraft engine.www.flyrotax.com
Your questions regarding 'who' are answered in the SB...Ouch, just delivered engine still in box in the serial number range, guess that's a blessing in disguise. I presume this is covered by warranty and/or Rotax Care. Next hurdle will be when and where will the inspection tool be available and who has to do the inspection to not void the warranty. Can a repair center do the inspection and repair or must it be a service center? Inquiring minds etc....
It appears to be a problem in manufacturing since Jan 2021 to Oct 31 2024 and the serial number list would say its a whole lot of engines. The good thing is we have not seen a bunch of these quitting so a relative likelihood of a single engine to be affected is small, but we still got to look for it.
I don’t see the builder listed. Am I missing something? What are those who have an engine in their garage and a plane that can’t fly supposed to do? Box up the engine and ship it to Lockwood???Your questions regarding 'who' are answered in the SB...
Good reason for builders to spend a few days at Lockwood getting their iRMT.I don’t see the builder listed. Am I missing something? What are those who have an engine in their garage and a plane that can’t fly supposed to do? Box up the engine and ship it to Lockwood???
If you read the SB, a line maintenance qualified person can do the test. That's a two day class at a couple of places, including Lockwood. I found a friend that took the class and has the card. Heck, I might take it myself. The hard part is probably getting the flow meter setup together.I don’t see the builder listed. Am I missing something? What are those who have an engine in their garage and a plane that can’t fly supposed to do? Box up the engine and ship it to Lockwood???
I concur about the inspection by an IRMT, the hitch is if the nozzle needs replacing the Rotax Care info leads me to believe its a distributer service center or an approved repair center. The time issue will be the special tool and lack there of. This may be a opportunity of putting together a traveling test kit together for members to "borrow" and pass along. Do we know where the 3 tools are headed? Lockwood, Aeromotive?In most parts of the country it should not be hard to find an IRMT. I think you'll be surprised how many are out there. It's also an opportunity to network with another Rotax person, maybe even another builder. There's lots of us out there. The inspection can be done by the lowest level, but the nozzle replacement requires a higher level and could be a little tougher to find. In any case, start by talking to one of the big distributors and sort out warranty questions then find an IRMT to do the inspection. Hopefully that's all that is necessary.
There will be some delay due to the special tool. Hopefully it's a short-term problem and a 3D file gets circulated so that we can just make that part.
Flow meter setup should even be pretty easy once we have the special tool. As I understand things, so far there are only 3 on the way to the US from BRP! There is some hope that the meter assembly will fit in place in the RV-12 without pulling the engine, but I'm not sure it's actually been in anyone's hands to try.
Yes, and a year to inspect hundreds of engines, repair those that need it with 3 tools....I hope they can ship more in a hurry. And here I thought radiators were going to be my rate limiting step. :>)My educated *guess* would be Motive, Lockwood, and APS (previously Leading Edge).
If you’re a member at Rotax-owner.com
forum, they have publish that Rotax will be providing them a file to 3D print the tool and the file will be shared with members to print their own.
A Rotax iRMT isn’t required to perform the work, but it might be required for Rotax to provide and reimbursement. Under “accomplishments” the SB says “Persons approved by the Aviation Authority”. If you have your Light Sport Repairman certificate, this means you.
I received my engine last week and I will need to comply with the SBIt will be interesting to see how much this further delays Van’s shipping times on Rotax engines since the SB says corrective action needs to be done before delivery.
I'd be interested in knowing what led to the SB? The date range of the S/N suggests something changed around 2021 (fortunately, after my engine - which hasn't even been started yet - was delivered). Was there some guy hired who loved using Loctite?
Fun one to speculate on, and I doubt Rotax will ever say. My first reaction was a person not properly trained, maybe rotating through different roles on the assembly line? Maybe an accidental swap or mis calibration of whatever they use to apply the thread lock. Are they counting drops, using a brush, dipping the nozzle? Do they even try to be precise?
Further down the rabbit hole, you can take a look at SI-912i-028. This service instruction is what Rotax points to for more info on application of thread lock to the nozzle. If you read the SI and actually go look up the properties of the Loctite products (243 and 603), they seem like they could be reversed. 243 is for threads and 603 is for mating cylindrical parts...but the SI has you put 603 on the screw threads and 243 on the nozzle. This SI was published in October 2021.
May be the factory guy was following instructuctions "Apply a small amount of LOCTITE 243 to open end of the oil spray nozzle.Note: Make sure oil supply passage does not get blocked by LOCTITE!" straight from SI-912i-028 paragraph 3.5.4 page 7.Fun one to speculate on, and I doubt Rotax will ever say. My first reaction was a person not properly trained, maybe rotating through different roles on the assembly line? Maybe an accidental swap or mis calibration of whatever they use to apply the thread lock. Are they counting drops, using a brush, dipping the nozzle? Do they even try to be precise?
7705061. I made it by the skin of my teeth.The amended SB picking up the iS engine changed the starting serial numbers. Make sure you print the two page addendum to see the difference. The iSc engines start at 7702217 whereas the iS engines start at 7706003. I didn’t catch this until I was talking to Dean Hogal at Lockwood. Made me smile as I dodged the bullet.
That's good to hear. Are you able to complete the SB yourself? I feel the same as you, the only issue is that I don't have my Repairman certificate yet since my plane doesn't have its airworthiness nor do I have the iRMT certification from Rotax. I understand this to mean I can't compliantly do the SB myself. I could get my Repairman cert, but I'd have to get my airworthiness first and that just feels weird to have a completed plane and then take the motor off to do the SB. Maybe the DAR wouldn't even declare it airworthy without completing the SB?My new and yet to be installed engine IS in the recall group BUT after talking with Lockwood I am not really concerned about this item. Lockwood is most excellent to deal with and they have yet to find a non compliant engine and they will lend me the tool required to do the inspection. Cannot ask for better.
So, that just leaves me with asking an iRMT rated person who lives nearby to drive to my garage and do the inspection, or for me to go do the iRMT training myself (maybe not a bad idea anyway).
I know in your later post you said the SB doesn't apply to your SN. But if it did remember there is no requirement for you (ELSA out of warranty) to comply. It is up to you as the owner to decide what SBs you want to complete. The only way this SB would be mandatory for you is if the FAA issued an AD to complete it. (not likely)This is a serious inspection that I believe will require removing the engine from it's mount in order to access the area with the measuring tool that appears not to be available yet. Concerning the 200 hour exemption.... is this arbitrary much like the 5 year hose replacement issue? My engine has 166 hours. The original builder flew it 12 hours from Oregon to Louisiana when it had 100 hours on it. Looks to me that if there was a problem with lack of lubrication it would have shown up during that 12 hour flight that was flown in legs of 3+ hours over a two day period. Am I looking at this wrong? Maybe folks that have experienced problems with this issue will respond to provide us some feedback.
A data point - I received notification from Van’s on 12/24/2024 that they were holding my engine that was otherwise ready for shipment to complete the Rotax SB. I was notified on 12/31 (1 week) that the engine was shipped with scheduled delivery on 1/10/2025. Hopefully the same timeframe will hold for other engines that Van’s will test prior to shipment.It will be interesting to see how much this further delays Van’s shipping times on Rotax engines since the SB says corrective action needs to be done before delivery.
ecclestonaviation.co.uk
