Recently had to replace two tubes, one each side, one flat away from home and one thankfully in the hangar. Both were pin holes in the side wall with no apparent cause from the tyres GoodYear 3s. Run at minimum 40psi ..Both Tubes were the Aero Classic from Desser bent valve TR 87-70*.
Think others have experienced pin holes with these tubes. In the bent valve configuration I think GoodYear, Aero Classic and possibly Michelin are the options, just wondering what tubes others are using ? Any/all comments appreciated.
