I'm helping another RV-9A owner with some braking issues.
First off, I have been in contact with George at Matco and he acknowledges the issue and is looking for a solution. He thinks that other RV's have also been using this dual piston caliper setup, but isn't sure, so I'm asking here.
Here is the situation: The dual piston calipers have a double thickness "brake plate". This is the part of the brake system that bolts on to the Van's U-403 brake flange which then is bolted to the gear leg to hold the brake system. The extra thickness of the brake plate precludes it from sitting on the outboard side of the brake flange, since there isn't enough room between the plate and the bolt that goes through the axle and brake flange. Installing the brake plate on the inboard side biases the calipers too far inboard and the outer pads when bolted onto the caliper (through a spacer) will lock up the brake disk rotor. The brake plate location means that the caliper pins can't "float" around the holes on the brake plate and stay freely over the brake disk rotor. The old pads were horribly worn and cooked on the outboard side and the inboard side pads were barely worn.
A couple of captioned photos are here:
https://www.overthehills.com/Airplanes/N762HV-Annual/n-3H5TWd/i-GG87Gms/A
https://www.overthehills.com/Airplanes/N762HV-Annual/n-3H5TWd/i-6Ld9c2P/A
https://www.overthehills.com/Airplanes/N762HV-Annual/n-3H5TWd/i-ZbZm4Lj/A
On my RV-9A I have the stock PH-1A single piston Matco brake calipers and the brake plate is only a single thickness. I originally had it mounted on the outboard side, per the plans, but later upgraded my Matco disks to their "High Energy" disks which are 1/4" thick instead of the stock 1/8" thickness. I had to move my brake plate over to the inboard side to accommodate this, along with using wider spacers and longer AN bolts. Blog post about my brake disk upgrade is here.
