milhouse1312
I'm New Here
Despite the risk of reigniting the war, I figured I'd consolidate a few thoughts I've had recently as I'm beginning to (re-)start my RV-14A project.
Prior to my laser cut parts replacement (and even after), I spent a TON of time trying to figure out what process to use to prime. I spent so much time, in fact, that I've actually decided to not prime... at least for now. Here's why:
- Priming is extremely time consuming and can add significant costs to the build. I never made it far in my kit before I halted due to the LCP issue, but I'd say between 1/3 and 1/2 the time I spent was on priming or prepping for priming. (i.e. scuffing parts, then rinsing, cleaning and degreasing, drying and finally priming, then waiting a day for the primer to cure.) It's a time sink. I'd estimate it could add 500 hours to the project overall. Between that and avoiding nasty chemicals, any hit to resale value (if any) is counterbalanced by the significant reduction in time, money and potential health consequences. Time is money. Materials cost money. Health is priceless.
- Priming will add weight. I plan on flying the plane primarily as a cross country machine. When loading up the airplane including the baggage area, the extra weight might adversely affect weight and balance, especially if that extra weight is way aft in the empennage I plan on restarting soon.
- I don't know where life will take me, but I currently don't live in an area with corrision problems. My local flight school has a 182 that's been sitting on their ramp in the elements for decades. Their mechanic has told me that airplane doesn't have any corrosion issues. He does apply ACF50 as a preventatitve measure to their unprimed airplanes every few years. Takes two people an afternoon. I've been there a while and have never seen the 'weeping' people on here complain about. Even if I end up in a corrosion-prone area, I will hangar the plane unlike my local school.
- I imagine I'll be done flying 30 or 35 years after this project is completed, and would almost certainly give up any aerobatics long before that. That means that if problems do start occuring in a decade or two, I'll still have an overbuilt airplane for the cross country mission.
- If corrosion becomes an issue, Corrosion X or ACF50 are options. There may even be a better product in the future. If it becomes a massive problem... well... I built it once, I suppose I can rebuild or build/replace major assemblies again. After all, I likely saved 500 hours the first time around.
- Here's the kicker: many builders who have primed their airplanes say they wouldn't prime their next airplane.
