Is there a "standard" (or do/don't) wire routing method to get wires from the firewall area to the subpanel/panel? I'm mostly thinking about wires coming from the fuselage/wings, not from the engine. Unless I'm missing something, the plans seem pretty much silent on anything related to wiring. I think I'm going to mount a piece of angle across the bottom of the two subpanel to firewall ribs to give myself more lateral options for attaching clamps and getting the wiring to the subpanel, vs being confined to only running it along the bottom edge of each rib (?). Any lessons learned with running the wire bundles through holes in the subpanel vs not drilling holes and dropping them underneath the subpanel instead?
The cutting of the monster hole for the center stack seems to be a common question, so I'll go to the search results for that one!
