I didn't want to hijack the other threat Latech15 has, but I'm in a similar battle. I've read many posts on the topic, as well as Lycoming's docs.
I'm looking for anything glaring I missed before I start changing big things, like the cooler itself. New fuel and Oil hoses in the last 6 months, but this problem was before and after. I have Surefly on the left and a new slick on the right at 25 degrees, and I verified them both again.
RV6, O360, 850 hours on 25yr old motor. I do tend to run at 2550 and the stats from my last XC are...
OAT - 68 deg
CHT 350, 385, 392, 368
FF 11.8 - would love to see this come down, but if I lean any further, #3 CHT breaks 400 at this power setting.
RPM 2585
Manifold 20.1
Alt 8,500
Dynon says 61% power
Oil Temp 221
My real questions are. Do I build exit duct work to widen it up? Do I replace/inspect the vernatherm? Do I just replace the oil cooler with one that has more rows, which might mean fabrication and moving it to remote?
I didn't build this plane, this was all pretty much the way it came, outside of me removing a block on the back of the cooler and RTV'ing the baffle to seal it up better.
OAT - 68 deg
RPM 2585
Manifold 20.1
Alt 8,500
Oil Temp 221
