I FYI, Cyl 2 the
hottest of the 4 is where you see a sticky valve the majority of the time.
Ya'll keep talking about a hot #2 like it's some kind of special attribute of the 390. Gee guys...329 isn't hot, and temperature balance is entirely a function of the cowl and baffles.
Recall I've been running variable exit area for more than a decade. With it, I've seen CHT's from 280 to 380 while playing around with configurations and settings. Typical cruise CHT in my part of the world is 325~345 across all cylinders with mixture at peak EGT, i.e.
maximum heating of the exhaust valves.
More speed may require best power mixture. Here's an example; I'm in a hurry to get back to the office after a truck auction in Slidell MS, circa 2015. Mixture is roughly 100 ROP, speed 188 true. At 339F, #2 is the coolest cylinder, and the rest are 355~365.
I just had all the springs off the exhausts for a slide and wobble:
I have recently heard of several stuck valves with bent pushrods. Since I travel a fair amount (600 hrs in the two and a half years since completing my 14A), and much of it is over unforgiving terrain or open ocean, should I be concerned? Additionally flying Young Eagles is a passion of mine and...
vansairforce.net
I have an RV-14 with an IO-390EXP...Now that the ambient temps are cooling for the winter, we are seeing sub 300º on all cylinders pretty commonly. Our A&P is recommending that we try to bring those up above 350º.
FWIW (sample of one), I'd shoot for 330 cruise, max 380 climb.
I understand that a higher timing advance could bring them up a bit. However, both E-mags, and the engine builder do not recommend changing the timing for the purpose of bringing up the cylinder head temps.
Agree. Don't do that. It also adds mechanical stress. Plenty of ways to increase temperature without the stress.
Has anyone been successful making baffling changes to bring up the cylinder head temps a bit?
In general, make baffle mods to change each individual cylinder, and cowl mods to change the cylinder temperatures as a group. Reducing either inlet or exit area will raise CHT, for an individual baffle wrap, or for the entire cowl. However, there's more to both than simply reducing area, so individual results vary a lot. Done right, reducing cowl exit area is superior to an inlet reduction.
This is a reverse cowl flap I use on my 390EXP. It will give the CHT numbers you what. DanH did the design work I did the flight testing. DanH has the mold, I did not contact him to see if he is interested is selling a kit.
I am not selling a kit. This was an experiment, conceptually like the outlet afterfairings Larry Vetterman was working with at one point. It makes half the exit area variable for the early RV-14 cowl. Note the Anti-Splat kit on the right. The variable exit allowed Marvin to control CHT, but damping the whole cowl made oil cooling marginal.
