Best advise I can give you about winter flying (based on over 20 winters in RVs) is get in it & head down to Arizona
But if that’s not practical, follow all the tips offered above. & below.
Maybe prioritize first with drafts & air leaks:
- biggest culprit is the lower side seals on the canopy, tip up or slider same problem, as the plane gains speed the canopy lifts & opens a gap below the canopy allowing warm air to be sucked out by that low pressure area over the wing. Work on a seal that minimizes this.
- tip up, proper sealing on the rear canopy edge is just as important as the front cowl/canopy edge. Tighten up every potential air leak you can but not so tight that you create problems for hot day flying later (yes, the Prairies have some of them too).
- slider, roll bar sealing is important in preventing water intrusion & heat loss out the top low pressure air flow over the canopy. A large air draft inwards happens along the rear edge & especially the rear track of the slider canopy, so you need to come up with a sealing solution there.
- baggage area (6,7,9,14) rear bulkhead, all those horizontal stiffener ridges are great inward air leaks especially if those lower canopy side seals haven’t been dealt with. A good solution there is little foam wedges glued into each stiffener ridge.
- side NACA vents, small foam plugs fixes these air leaks
- fuselage air leaks, caulk & plug all around wing spar to side skin joints, seal all wing wiring grommets, fuel line to skin grommets, install aileron control link boots, install flap linkage boots, caulk rear spar to side skin joints, elevator push rod boot under baggage floor, tip up canopy hinges, get the idea?
- single heat muff is probably good enough if all the air leaks mentioned have been treated.
- carpeted floor & seat areas help. Interior upholstered side panels help.
- two defrost slots cut into the glare shield with small fans blowing warm air from behind the panel works great.
- electric heated seats will make your butt & back feel good but will not help on warming the rest of your body, try to retain as much of that exhaust muff heated air as possible.
- oil cooler, is a good idea to use some form of airflow restrictor, there are a few choices available or use a restrictor plate, your choice.
- there is a LOT of good local advice about best practices for winter engine operations.Seek it out & heed it.
- SURVIVAL, no matter how comfy you make your plane, DRESS for the unexpected!
Or you could try my first (best) bit of advice & come south…
Enjoy your bird!
