Source for Alternator belt?
nightflier
I changed my IO540D4A5 narrow deck, to a Zero time Lycoming OVH engine.
Now the alternator belt wont fit. The old belt was a 3VX355, but it's to short.
A 3VX370 is the right length, but even though it's 3/8 wide, I think the grove
is different. Don't even bother asking Vans, they don't have a clue, that's
pretty sad.
Thanks!
[email protected]
pretty sad.
Thanks!
[email protected]
V-belt cross section is defined (by trade specifications) by the first two digits of its description - ergo, a 3V belt of any length is going have the same cross sectional dimensions. The third digit (X) means that the back face of the belt has been "notched" to give better performance around smaller pulleys.
HFS
3VX trade size - 3/8"w x 21/64" deep
Same alternator?
Same alternator mount?
Same flywheel?
Not familiar with the terms narrow deck or OVH as they would pertain to spacing differences. Can you take measurements of new vs old to make sure you have the correct mounting bracket for the replacement case?
HFS
Great info, thanks!
Same alternator?
Same flywheel?
Just discovered the bracket is different! Thanks.
Same alternator?
Same flywheel?
Take your old/too short one to your local NAPA Aircraft Supply and have them measure it and find what they have that is similar. There is no secrete manufacturing method that makes them different aviation from auto. Have them give you several different sizes so you don't have to keep going back for a longer/shorter one. You can take the 'wrong' ones back. A half-inch difference in the length of the belt can make it either fit or not fit. Ask me how I know that........... 😉
pretty sad.
Thanks!
[email protected]
The variations of what can go firewall forward (or anything else not in the plans, for that matter) would be difficult for anyone to figure out that is not standing next to your airplane to see what is there. The starter ring is usually the same but the alternator pulleys can be of many different types as well as the alternator brackets/setup. The clues we will give you are based on what we have on our Magic Carpets and might be exactly what you needed to know.........or not help at all! 😉
