I’m installing a regulated Garmin GAP 26 pitot tube with AOA on my RV-8. I know a lot of you have installed your pitot tubes behind the spar and that it works fine there. But I’m concerned about tie down chains hitting the pitot tube if it’s there. I was thinking about attaching the pitot tube mount to the inspection plate for the stall warner in front of the spar so that the pitot tube will be ahead of the tie down ring. That’s in line with the instructions, which say to put it on an inspection plate in the forward 25% of the wing chord. But if I go that route and don’t put holes in the spar web for the pitot and AOA lines, then I will have to run those lines outboard a few bays and then down through a lightening hole in the spar and then back inboard through the designated holes in the spar. Has anyone gone this route or see any problems with this approach?
