Hi all,
Last week I did my fuel flow test and I realized that G3X was always showing 0 GPH for fuel flow. I use a GEA24 with red cube FT-60 as fuel flow sensor.
Troubleshooting the issue I confirmed continuity of all wires from red cube to the GEA24 connector, tried to move the connection to another connector (J244/J243) and made sure that software configuration was correct for EI FT-60 fuel flow sensor. I tested the voltages and ground on the 3 sensor wires and even bought a brand new sensor and re did all the tests.
G3X still showing zero gallons per hour. At this point, I can’t think of any other thing other than a failed GEA24 unit.
Has anyone ever had similar issue?
Appreciate any feedback.
Thanks!
Thanks!
