A friend of mine had experienced an intermittent power loss on takeoff today (landed safely). Will outline below. O-360 with dual Pmags and CS prop.
After the failure and some checks he performed multiple full power run ups and everything was normal.
ANY recommendations on other items to check would be appreciated.
- complete loss of power at around 300’ AGL
- partial power returned just enough to get him over the trees to safety.
- electric boost pump was not on during takeoff
We spent the day looking over things in an attempt to identify the cause.
- tanks were sumped before flight, but we sumped both again multiple times including raising the tail in an attempt to drain any remnant of water which might have been behind the sump.
- checked for pressure and vacuum on inlet and outlet of engine driven fuel pump
- checked all linkages for throttle/mixture
- pulled all plugs and ohm checked leads
- checked gascolator
