dnickerson46
I did not build my -9A and during the recent condition inspection, I found the nose wheel fairing brackets were cracked. The original builder created two separate brackets on each side of the fairing and riveted the brackets to the fairing. The cracks are most likely caused by the back and forth motion and vibration between the brackets. I ordered new brackets and I'm installing the brackets per the plans. By the way, the metal was very brittle.
Here is a picture of the nose fork. It has a extra reinforcement that is not in the plans. Was this plate recommended at some point?
