I'm interested to hear how the install goes.
Frozen bolts or room temp?
What lubricant?
Difficulty from 0-nightmare?
Any special tools?
Brass hammer?
Rivet gun?
Etc?
Hey Larry-
I realize you weren't asking me, but here's how it went in my case;
-The bolts spent the previous night in my freezer and came from home in a cooler with ice packs, but I seriously doubt that it did more than just make me feel better.
-we put the wing on with a couple of rig pins and the holes lubed with LP2
-an inspection mirror and flashlight was handy to verify when they were close enough to start thinking about installing a rig pin.
-used a plastic dead blow hammer to encourage the rig pins in, and a wooded dowl rod to help drive them back out when it came time to put a bolt in that hole
-I started each bolt by tapping in with a plastic hammer enough to be sure they were actually going in and not hung up, then drove them the rest of the way with a rivet gun turned down to about 20 psi with a nylon tip set. A flush set against a wood block would work too.
It wasn't to bad. Took two of us about 3 hours to install both wings, My brother in law is an IA I'm an A&P, but my main qualification for this job was owning a plastic BFH.
I know you're building a tricycle gear and that the gear weldments make this a completely different kind of job, but it seem like the majority of that pain will come with getting the nuts torqued down. I can see how a couple of things a guy could do to make this harder than it needs to be would be to shove a rig pin into a hole thats difficult to access the fwd side when the time comes to drive them back out, or to not watch the washer stackup because some have washers under the bolt head rather than the nut.
