Quick dimension question
JBarsness
Good Evening VAF!
I am looking at a hangar rental option for my RV-10 (still under construction). It’s an older hangar that has a post to the side that would clear the horizontal stabilizer tip but not the wing. I’m concerned about the clearance between the trailing edge of the wing and this post when the door is closed.
Can anyone take a measurement from the tip of your spinner to the trailing edge of the wing on your RV-10 and tell me that distance?I need to move quickly on this so any help you can provide would be greatly appreciated!
JB
Thank you all. This particular hangar would have put a support post less than 2' from the trailing edge of the wing with the spinner less than 6" from the door. Doable, but not ideal so I passed on the hangar.
