Installing wheel fairings—a better way
hgerhardt
While researching how to replace my old RV-6’s 1-piece wheel pants with today’s pressure-recovery units, I came up with a good idea: by assuming the wheel axles are aligned correctly to the airplane (they are), a jig could be built to hold the brackets in rig to install them to the fairing shells. One could also make a template to roughly cut out the wheel opening using the same jig to locate the hole. And with the fairing upside down in the jig with the wheel opening on top, one could reach inside to back-drill the screw holes from the brackets to the fairing shells. None of this silly magnet and/or laser action to find the holes from the OML. And you could do all of this on a workbench instead of on your knees. And since everything is rigged to the axle, you’d be assured the fairing will fit the airplane perfectly, even though you rigged everything away from the airplane.
While Van’s won’t supply a STEP file of the fairings, they do have good CAD-generated drawings which I used by importing jpg’s of various views from drawing C2 into CAD and reverse-engineering, thus enabling the jig. Specifically, the Bottom View and the Side View and corresponding Section A-A of drawing C2 were used. This example is for the tapered-rod gear RV-4, 6, 7, 9 and A-models, but the same idea should work for all RV’s. Shown are the Van’s drawing views superimposed on the jig:
This jig uses a ‘faux’ axle to hold the inboard and outboard brackets in rig. The aft fairing shell is located by the Y- and Z-centerlines of Section A-A at the fwd/aft shell intersection plane and by the narrow trailing edge. This avoids having to eyeball the centerlines of the forward shell which is difficult due to the nose being so blunt. By using the section cut of the joint between the fwd/aft shells together with the narrow trailing edge, a more accurate centerline can be had. Even the screw hole locations are on the jig.
My faux axle was 3d printed, but you could make it from plywood too. The jig is made from Baltic birch plywood which is stable and straight. The purple removable piece which holds the axle is symmetric so that the same jig can be used for LH and RH installations. In another post, I’ll attach scaled drawings in pdf if you want to make a jig without all the engineering. Print them full-scale and use the paper patterns as templates to cut the plywood. Or you could borrow my jig, now that I’m done with it.
Note that I filled the gaps between the brackets and the inner moldline of the fairings with thickened epoxy as Mike S showed in a previous post. This gives better support for the screws as well as prevents the fairing from flexing when torquing the screws. It’s easy to do this in the jig with its great access. No need for “tweaking the brackets” as I’ve read on VAF. As you can see, the brackets fit nicely as-is.
Note the tire cutout template on top of the jig. Use a Sharpie held vertically to transfer a line onto the fairing. Doesn’t have to be perfect as you’ll fine-tune the gap later.
...Another use for the jig is to hold the actual brake-wheel-tire package to fine-tune lateral spacing of the wheel assembly via custom-length U-408 bolt spacers as dwg C2, sec A-A shows. Once that’s done, fine-tune tire-to-fairing gap all the way around, with the tire and fairing hole facing up and on the bench…so much easier.
After I installed these on the airplane, I checked alignment via the "normal" way as shown in the manual. They're amazingly accurately aligned.
If you find this content interesting, I'll detail how I installed the new gear leg fairings and how I fabricated the intersection fairings.
View attachment 71798View attachment 71799
Please publish the pdf file for those of us that are CAD weaklings... Good work.
Attached below is a quick-n-dirty drawing package in a zip file. Drawings are full-scale, so print them at 100% scale and use the drawings as glue-on templates. 3M 77 spray tack works well for that. I've included an STL file for the faux axle, or you could make it via the supplied dimensions. In order to install the brake/wheel/tire package, one way is to print two of the axles and from one cut off the big flange which supports the inboard fairing bracket, or maybe even easier, get a piece of 1-1/4" dia round stock and drill/tap a 1/4-28 hole centered in one end. Use the steel fairing bracket flange which comes with the wheel/brake package instead and slide that whole assembly onto the shortened faux axle (without the plywood axle support, since by now you have the fairing brackets installed on the fairings to support the axle).
  • Fairing Assy.zip
    Fairing Assy.zip
Note that I filled the gaps between the brackets and the inner moldline of the fairings with thickened epoxy as Mike showed in a previous post. This gives better support for the screws as well as prevents the fairing from flexing when torquing the screws. It’s easy to do this in the jig with its great access. No need for “tweaking the brackets” as I’ve read on VAF. As you can see, the brackets fit nicely as-is.
View attachment 71796View attachment 71797
The axles normally have a bit of toe-in or toe-out (I can't remember which) so if this jig aligns the fairings perpendicular to the axle then the fairings will be not exactly parallel to the fuselage centerline and will be angled instead depending on toe in/out, if I understand this method correctly?
How did you ensure pitch alignment of the wheel pants with the side longerons?
Unless the parasitic drag from imperfectly aligned wheel pants ruins the OP’s quest for every fractional knot (if such is desired), then presumably the nearly equal yawing moments for each pants’ nearly equal toe-in-or-out could cancel out to nearly nothing? Additional pitching moments probably also small, compensated with the elevator trim?
Actually Van's specification is zero toe with longerons level and weight off wheels. That's what it is for tapered-rod taildraggers, but I'm fairly certain the tri-gears are set up the same way.
Pitch alignment of the fairing comes from the steel fairing bracket flange (don't know the official name for that part), the part which holds the brake caliper to the axle. If the hole pattern in the flange is not parallel to the level aircraft centerline, then you'd need to tweak the holes in the aluminum fairing bracket to match. I just had to do that when fitting Beringer brakes. Notice on my hand-drilled axles (my -6 came before those holes were drilled at the factory), I had to rotate and re-drill the hole pattern by 30 deg.
How I figured out how far off the hole pattern was:
Mine is a -6A and perhaps there is a difference in the toe in/out design because during construction when the fuselage was still inverted in the jig there was a step to clamp the gear legs with a shim between the end of the axles and a straight edge before drilling the holes through the sockets and the top of the gear legs. The newer kits have these holes drilled by the factory.
The axle brackets for the brakes were also out of alignment when I tried to fit them and the solution was to weld closed the holes and drill new ones. Note the shape of the bracket is a bit different because the originals were missing from the kit and I ordered replacements from Vans.
I don't think I could have fitted the wheel pants any other way than by lifting the fuselage off the ground, unfortunately. It would be much easier to be able do this work at the bench.
I would do that the OP did and make a jig if my plane was on the gear. If it isn’t, here is an alternative
Since my 8 gear is a slab attachment, and is 90* to the fuselage, it was easy to bolt to some 2X4’s and work upside down while comfortably sitting on a stool or standing. I remember how uncomfortable it was fitting them on my 7A.
Which leads me to think how I would do tubular rods and here is how I would tackle it. Before mounting any weldment for landing gear, I would mount the weldment upside down to a wood base. Insert the gear legs and get them in position with the axles in line with each other.
With no weight on the gear, you can get the right flight alignment, fit, brakes, and fairings while sitting on a stool. And save your knees and back.
When I was done, I literally just bolted the gear assembly in place on each side.
Wow! And this is an EASIER way to do it?! No wonder the 9A I bought recently came with unmounted wheel pants - in a cardboard box! 😳 Apparently even after 10 years the thought of dealing with this was still a bridge too far for the original builder! Anyone know of a build assist center in SoCal?!
Taking this a bit further, assuming the high degree of precision in current parts production from the factory allows alighnment and assembly on the bench and off the airframe, what is to prevent the wheel pant producer from pre-molding index marks for all bracket mounting holes into the raw part and doing away with the need for jigs and faux axles of any sort? Seems like the next step. Just confirm/tweak the alignment on the plane once you're done drilling the pre-marked holes...
The design is awesome and I believe in promoting ingenuity. I think he could easily market to builders or maybe Flyboys.
Sorry to thread drift, but If you want another process, the picture should suffice.
The slotted frame makes it easy to use the jig for mains and nose. The airplane need only be leveled just high enough so the tires are clear of contact. There's a bolt in each corner that clamps the parts together and acts as a foot to level the jig. The end piece angle is threaded for the bolt. Just take a bolt out. Open the frame. Slip it in place. Replace the bolt and level the jig. The slot on each vertical is for a 3/16 rod. The pant has a hole each end at center for the rod. Once assembled, the pant can be moved in all three axis, plus forward/aft and starboard/port, till aligned then the rods clamped. The green tape has a line aligned to the aircraft center line. The two end brackets have a center line aligned to the pin slot. When the lines are matched, the pant is aligned to the aircraft center line. Mains are done the same way by drawing a line equidistant from the centerline measured to the tire center. I have a draft article for Kitplanes if anyone wants the long winded version.
I just gave the prototype away.
I just followed the plans and did it on a level floor. It was a pain crawling on the floor but looking at my build log both sides were done the same day. They ended up parallel to 1/16” both laterally and vertically.
An Aside: On a -8 with Classic Aero tires you want to be able to get your thumb between the tire and the wheel pant or your first bad landing will blow out your perfect fiberglass job. First hand knowledge.
While a great in theory, one only has to look at the scribe lines on the rv-10 cabin top to see how it would go. The scribe lines aren't even close...
This is Genius.
Wow. This will be my winter project.
Imitation is the highest form of flattery.
Way to go.
Daddyman
Back in 2020 we developed wheel fairings for 6.00-6 tires using exactly the "next step" philosophy you, Bill, mention. There have been plenty of lessons learned along the way but the concept works and has proven sufficiently successful that we're introducing fairings for 5.00-5 tires - also in carbon fiber - with dimples for #8 flush-head screws molded-into the composite fairings and attach brackets supplied with matching screw holes.
Field experience gained thus far indicates accurate alignment and greatly reduced installation time...all without jigs, lasers, or strings.
This is excellent, I am just about at this point. How much would I be able to purchase this jig from you or have you cut the parts of the jig and send them to me? I have 3 builders in my area all with RV7A’s that could very much benefit from a jig like this. Feel free to PM if you’d like.
Once again, I was too early to the party! I'd have bought these had they been available in February '24. I did (extensively) look at your fairings but decided they were just too big for the 5.00x5 tires. And bravo for spending the time to put accurate dimples and cut lines into the molds. The Van's parts have cut lines but they're so far off that they're absolutely useless. See the cut lines below for the tire opening; the inner line is what's molded in and the outer is what I did from my pattern:
I attached a drawing package on post #5. Just print all the sheets full-scale and build your own jig. Probably faster to do that than for me to find a box and ship mine.
Surely someone in your group has a band saw and a circular saw? Also you can have the faux axle made at any number of vendors, but one of the better ones lately is Jawstec.com.
The slotted frame makes it easy to use the jig for mains and nose. ........
Yep, I saw your original post in researching here before I got started, and appreciate your contribution. Certainly a good way to hold the fairing. Just doesn't really help with wheel opening cutting or back-drilling the brackets. Or saving your knees. However, if I hadn't thought of what I did, that's the route I would have taken!
No reason we should have work so hard. Holes should be molded in.
For those who can, there are kits. For those who can't (or can't be bothered), there are flying airplanes for sale.
Yes I could do that but I’d rather not reinvent if I didn’t have to. I figured I’d ask. Thanks
Your new wheel pants will be very popular.
I had to replace and align one of my mains that got damaged.
Aligning and drilling wheel pants is a PTA.
This could save 50 hours or more. Most of us spend 3 or 4 hours figuring how to proceed.
Do you have pricing and ETA ?
Really interested in this. I realize you make a lot of taildragger parts, but are you planning to sell 5.00-5 nosewheel fairings as well?
We're shipping RV-8 kits now, others are in-work. Price for the RV-8 kit is $1575 plus shipping.
The fairings themselves are, of course, ready now and brackets are either ready now or soon to be ready but the lower intersection fairings for any model except RV-8 still need to be finalized and produced.
Which model RV are you building?
Maybe a wee bit harsh. There are other reasons folks buy vs. build. In my own case, I am one who absolutely “can”. However, due to my age and other life constraints I have chosen to buy and fly now - while health supports it. Tomorrow isn’t promised. Now that I am actively flying (and loving my RV9A!), I actually am considering whether the RV15 will be my next plane - which I will build. In the meantime, I’m sorting out a few squawks - and once the weather cools a bit so I can actually work in my hanger - I’ll start on those blasted wheelpants! 😁🤪 I like your idea, and may give it a try. Some thoughtful work you’ve done there.
I’ve noted over the years that I’ve participated in these forums, that fiberglass is high on the list of builders disdained activities. As someone else noted above, it doesn’t have to be this way. This is one point of refinement that could definitely be added to Van’s kits. In this age of CAD/CAM much is possible. Ken K has likewise demonstrated that with his products. (He just needs to add the “A” models! 😉)
Yes, we can sell you a kit for RV-8A main wheels for $1475 plus shipping but it will NOT include lower intersection fairings...you'll be on your own for those which is the case with the standard wheel fairings. Please e-mail, call, or use the contact form if you'd like to order. https://www.skydesigns.aero/contact-8
Ultimately I would like to get these but what I really need right now is for a 5.00x5 nosewheel. The mains don't take much of a beating and seem to be holding up well, but the nosewheel fairing is a little damaged from not having enough tire clearance and the usual vibrations that can occur. I would contemplate upsizing the mains with your 6.00-6 kit/fairings down the road. I'm really impressed by your products, I just wish there was more for legacy models (or at least 7A/8A/9A) with tricycle gear. Only so many hours in the day, I guess.
Slab gear can be jigged on the bench with a simple longeron substitute. Allows doing brackets and fairings while standing. Pretty sure it could be done with any of the gears, and I recall someone doing it by jigging a motor mount.
