We just replaced our backup alternator with a MZ-30L generator and I have an operational question. We have removed the pin that causes the MZ-30L to operate at a lower voltage level (14.2V). The goal was to allow both the primary and backup alternators to be enabled at the same time without causing issues.
However, we found that after startup, when the battery is low, the primary alternator is not able to keep the voltage high enough to prevent the MZ-30L from also generating charge (based on the output on the "Enabled" wire). So, after startup, if both are enabled, we have both alternators generating power. Is this going to be bad for either device? Or is it only an issue to have both enabled when the battery doesn't need that much current?
In the future we may switch our primary alternator to a higher-voltage (it is internally-regulated), but until then I need to know if our SOP needs to be to keep the MZ-30L disabled when not needed so that we can guarantee it doesn't generate electricity simultaneously with the primary alternator.
