Enlarging Fuel Line Brackets for 3/8" Return Line
czechsix
For those of you who have installed a 3/8" return line in your RV-14, how did you enlarge the upper slot in the UHMW fuel line brackets (F-01498A & B)? They come from Van's sized for 1/4" return lines but it looks like SDS and DeltaHawk installations are both using 3/8" return lines. I'm thinking it would work to screw the two halves together and then run the unibit in from each side to 3/8", then disassemble and enlarge the slots to match the hole, but thought I'd ask what others have found to work (or not work) to do this.
This is going back 6 years + but I'm pretty sure the return bung already installed in the QB tank VA-141was for a 3/8" return line. The vents where 1/4". Fuel line brackets F-01498 where for the supply lines and new brackets probably need to be added for the return lines.
I stacked A & B brackets, then freehanded w/ a Dremel IOT to make the slight adjustment to align w/ original mounts.
We make the returns in 3/8 tube, and make our own version of the F01498A&B to accomodate the 2 3/8 tubes.
Tom
Tom
Do your fuel line brackets fit under the standard aluminum cover that is provided in the RV-14 kit, or does that need to be replaced/modified to make room for them?
I have these in my -14. There’s no other modifications required. All that changes is the groove for the larger line is bigger to accommodate.
I put 1/4 return lines from the selector to the tanks so I didn't have to enlarge the brackets. 1/4 will flow 35 gal per hour @ 40 psi over the 24 inches of tube between the tanks and the valve.
I held both sides in a little wooden jig using #10 screws to ensure alignment (they get installed with #8 screws in #10 holes). Used a step drill to enlarge, then a flat file to take off the corners. I then used a round file and my vice as a filing guide. Don’t file too deep because the lines will contact the aluminium ribs.
You can see pics here:
Andair makes a duplex fuel valve with 1/8 NPT return for 1/4 in lines. A little more back pressure probably won't hurt. The 14 tank QB tanks already have 3/8 bungs installed.
The wait from anair was forever so I ordered the duplex valve from vans. It doesn't come with with right fittings so I swapped some off the one that came with my fuse and made it work with some an4/ntp fittings. Looks good to me. I'll let you all know how it works out in about a month. However the calculations say that those 1/4 lines should flow just fine and worst case you build a little pressure which isn't exactly a bad thing haha
