RV-6A, reports are the prior owner porpoised on landing and the second, smashed the front gear so hard it sheared off the bolt and ran the gear leg up into the cockpit. Logs show it repaired professionally and looks great. It also says the pilot side gear leg was replaced. Engine and prop full overhauled no sign any skin contacted the ground. In cruise it banks slightly to the right requiring a tiny bit of left aileron pressure. Today we noticed that the co-pilot side wheel is out of alignment towed outward 5 to 10 degrees. It would explain why it doesn’t push/pull out of the hanger without some effort and why it wants to roll right in flight. Flyable, landable, takes a little more effort than others I’ve flown.
My question, short of purchasing a new factory bent gear leg, is there any other way to tow in the gear to alignment? As I’m typing this, I’m pretty sure the answer is a new gear leg because if it was bent in the incident, possibly the leg strength has been compromised? Wanted to explore options before going for a new gear leg.
