Landing light blowing fuse
jmo3789
I'm New Here
I have recently been getting an issue where the landing light is blowing the fuse a few min after turning it on. Few minutes being 2 or 3 min after takeoff or getting in the pattern for landing. It doesn’t matter if it’s on steady or pulse. Then when the fuse goes I get a squealing in the radio when I transmit. Put the new fuse in squealing goes away. All connections seem to be good
What size are the wires going to the lights and how many amps is the fuse??? Maybe you just need a slightly larger fuse if the wires can accept the current.
You may want to try to localize the problem by disconnecting one, or both of the landing lights in the wingtips to determine which is the issue.. or.. if its the wiring going out to the wings that is the problem.
There are separate wires coming out of the Switch & Fuse Module to the landing light for steady and pulse operation. So that kind of eliminates most of the suspect wiring to the light. It is hard (but not impossible) to see a failure mode in the Switch & Fuse Module that would cause this. So my money would have to be a failure of the landing light itself.
As I am sure you know fuses don't have a sharp "knee". That is, everything is fine at 7.4 amps but blows instantly at 7.6 amps. You've probably seen this plot of current vs. time to blow for fuses...
So 2 to 3 minutes to blow tells me you are only slight over current. Bad wiring is usually either open or shorted to ground, but rarely "slightly" shorted to ground. So again, I think that points to a bad light.
Sounds like a wire has been chafing on something. With vibration it temporarily shorts.
On the RV-12 there are separate wires for pulse and steady landing light modes so if the fuse blows in either operating mode then it probably is not a single wire chafing.
On the other hand, the audio squealing is an intriguing clue. When I've had squealing problems it was the due to the intercom and not the radio. Power for the intercom comes from pin 22 which on a DB-25 connector is pretty close to (but not exactly next to) the landing light power pin 11. It seems like a long shot but it may be worth poking around the wire harness near the Switch & Fuse Module and inside the connector backshell.
Some landing lights have a switching power supply. One characteristic of switching power supplies is that if the input voltage goes down, the input current goes up. The vast majority of electrical problems are due to to bad connections. Bad connections can cause a voltage drop which in turn can increase the input current to a switching power supply. Increased current can blow a fuse.
Check the voltage as close to the load as possible using the load negative wire as the reference point. Voltage measurements without a load are meaningless. If the voltage at the load is low, find the bad connection.
I like the switching power supply / bad connection theory. The landing light connector is a cheap Molex that doesn't really stand up well to the elements. Here is my landing light connector I replaced last year...
You can see where one pin got hot because of a bad connection due to corrosion. Of course it is worth taking a look at the grounding lug also.
If you have any ring connectors into terminals blocks with screws, make sure that the screws are tight.
I had that issue, albeit in an -8. The problem turned out to be a terminal on the back of the landing light switch. Carling toggle switch with push-on connections. One had gotten quite loose and wobbly, and the terminal on the wire was blackened. I replaced the switch and terminal and never blew the fuse again.
I think I found the issue. The connector from the wing to the fuselage was a bit loose. I tightened it up and flew this morning no issue. However the squelching in the radio remains. I’m starting to wonder if it’s a feedback issue or gain issue of some sort. It’s only when I transmit.
What radio and intercom are you using? I had the squealing problem with my Garmin (Apollo) SL40 radio and FlightCom 403 intercom. The problem turned out to be in the intercom but I understand the SL40 leaks RF like crazy. I made this intercom filter, which helped quite a bit. If you have the FlightCom 403 I'd be happy to send it to you to try.
Okay it’s fixed. Here’s what we discovered.
1. We found the coaxial cable was rubbing the cable to the stabilizer. We zipped tied it to the other wires so it’s no longer touching.
2. We found the jacks for the headsets were a little loose. Tightened that all up.
3. We pulled the radio from the tray and replaced it snug. Went out this morning no issues clear as a bell. Thank you all for your suggestions
For those arriving via Google in the future:
Adding in that I've had the exact same squealing issue with my GTR200 3 times so far, close to a year apart. ATC was able to confirm the issue on their side as well. What's interesting is that it only occurred at specific frequency ranges, however those were different each time.
Re-seating the radio resolved it every time. The most recent instance, I've hit both sides of the antenna connectors with contact cleaner and put a dab of Loctite 242 on the thread underneath.
I added a hex key to my travel toolkit for re-seating the radio in the field.
