ReidW
Hi folks,
I recently got the workshop all set up, practice kits completed, and am starting to put rivets in the real thing. I spent a lot of timing getting my dimpling setup and technique just right so that the areas around the dimples have no distortion whatsoever, but I’m starting to put in the flush rivets on the VS and am a bit worried I’m doing something wrong. Prior to shooting the rivet there is no distortion but afterwards it looks like the river has pulled the skin just a bit tighter than the clecos could and the result looks like a bit of a dent/concave region around each rivet.
I’m using a mushroom set and a tungsten bucking bar, being as careful as possible to not let the mushroom set move or bounce. Pressure is set such that it takes 3-4 seconds to set each one.
I don’t have a buddy close by to compare with what it ought to look like and I haven’t seen one up close in a while so it’s likely I’m just being OCD, but thought I’d ask the experts before I get too much further. Thanks!
