Painful Sight to see (LCP's)
mulde35d
This is what destroying likely perfectly good parts looks like because you can't definitively prove they weren't laser cut. Had to cut these open to retrieve the nut plates, lead, and counterbalance weights that Van's doesn't provide through LCP replacement. The worst was taking the Sawzall to the fiberglass wingtips that have been riveted and then fiber glassed in place on the elevators to gain access to the counterbalance weights.
My old elevators look about the same -- although I hadn't put the fiberglass on yet.
I fully rebuilt my VS and Rudder -- I kept the old ones for backups.
Appears you didn't do any research.
"In short, the results of extensive testing of laser-cut parts manufactured for Van’s Aircraft shows that the parts are safe for use in aircraft construction."
My concern was primarily resale value. Based on what I have seen, I don't think the LCP issue was much of an issue. But I don't want to spend the time and money it will take to build an RV-10 only to have wary buyers one day in the future. Nor do I want to have to replace something in the future when an AD comes out -- I was early enough in construction that it wasn't the end of the world to replace them.
Like saying climate change might reduce the value of beachfront property.
But they also recommend that builders replace certain parts, for example red category parts, which they say are “difficult to inspect” and have a “reasonable chance of fatigue cracks developing in service”.
I thought it was "difficult to inspect OR have a reasonable chance of fatigue cracks developing in service." Extensive testing has not found any parts that have a reasonable chance of fatigue cracks developing in service..
Im taking mine to the gun range.
Im thinking slinging some lead at the now worthless aluminum will be carthartic for me!
Yeah. Let's revisit this in about 10 years or 1000 hours, whichever comes first.
I think there have been slight inconsistencies in the various deliveries of the Van’s position. I was just quoting the bullet points from the service letter for how they described red category parts. They don’t indicate whether it is one or all of the bullet points that qualify it for that category.
AC 39-7D Airworthiness Directives - AD’s only apply to type - certificated aircraft, engines and propellers, and appliances (?)
As a buyer I would be more wary of the builders shoddy craftsmanship and lack of pride in build before non-red LCP parts in an RV aircraft.
A lot has been written about LCP "resale value". The typical resale goes to someone that hasn't been reading every post on VAF for the last 5 years and are new to RV's. They are thrilled with the paint, avionics, and performance. For a pre-buy they go to the local A&P who is also pretty RV ignorant. Biggest concern (well justified) will be the engine. I doubt they will even know about laser cut parts until they own the plane for a year or more. Just my opinion!
Well said, IMHO.
I interpret it as any one bullet point is sufficient to qualify.
Testing has reproduced conditions equivalent to something like 14,000 hrs of continuous, non-stop aerobatics combined with flight-school level landings and other abuse. So lets revisit this in about 100 years or 10,000 hrs, whichever comes first.
I don't recall, in the Van's summary and detailed engineering explanation videos, any mention of testing of non-dimpled parts. Maybe I missed it, but it seemed glaring to me as I'm sure there must be non-dimpled joints in internal areas.
