Facet fuel pump help!
Capt
Seeking help from the knowledgable out there. My Facet fuel pump has gone to God after 37 years, I can’t seem to find same with the AN fittings as shown. Plenty available on the net but without the AN fittings, anybody?
cheers.
Yeah I’ve found the AN8 fitting to suit but that would mean I’d have to make up two new fuel lines, I wanna avoid that if I can.
The part number is stamped on the mounting flange. It is five letter number
starting with 40 for the cube pump.
Call 1-800-688-6946
Good luck
cheers.
I have 2, installed, but removed before using. Never saw gasoline or electricity.
I switched to the EFII system, which has its own pumps
Text me at 614 664 7851, if interested
Good Luck
Good Luck
Thanks for the offer but I’ve already bought a generic pump and getting new fuel lines made up. Anyway I’m from down under, not quite next door😉😉
