RV10 Door handle
flyboy143
Does anyone that converted to the recessed door handle have a standard RV10 door handle they are not planning to use. I need one.
Joe G
As a side note. The Aerosport low profile door handle has a 3/32 roll pin that holds the handle on at the pivot point for opening the door. Over time and use, the roll pin slides out of its engagement. It did on mine (about 1/2 way out) on both sides as I noticed on a pre flight check. My fix was to push the pin back in flush with the boss and use .010-.015 safety wire around the boss that the roll pin goes thru. It does not interfere with the door operation, and you can barely see it, unless you know it’s there.
